1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Cant build EPICS for power pc 40x
To: Chris Timossi <[email protected]>
Cc: EPICS <[email protected]>
Date: Mon, 07 Feb 2005 08:18:22 +0900
Chris Timossi wrote:
Has someone tried to build epics for the PowerPC 403 for vxWorks with gcc ?
I'm getting the following internal compiler error when compiling calcPerform.c
We have similar problem to compile EPICS3.14 for PPC/vxWorks2.0, but I don't remeber the
filename which caused a problem.
We needed to change gcc optimization level from to 3 (-O3) to 2(-O2) to avoid this compiler error.
Cheers,
Noboru
KEK,JAPAN
Chris Timossi
LBNL
/home/als2/devel/vxWorks/vxw_5.4_T2.0.2/host/sun4-solaris2/bin/ccppc -c -D_POSIX_SOURCE -DCPU=PPC403 -DvxWorks -include /home/als2/devel/vxWorks/vxw_5.4_T2.0.2/target/h/vxWorks.h -ansi -O3 -Wall -mcpu=403 -mstrict-align -fno-builtin -fno-builtin -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -I/home/als2/devel/vxWorks/vxw_5.4_T2.0.2/target/h ../../../src/libCom/calc/calcPerform.c
../../../src/libCom/calc/calcPerform.c: In function `calcPerform':
../../../src/libCom/calc/calcPerform.c:452: internal error--insn does not satisfy its constraints:
(insn 1771 55 57 (set (mem:DF (pre_inc:SI (reg/v:SI 27 27)))
(reg:DF 9 9)) 389 {movdf+3} (insn_list 54 (nil))
(nil))
ccppc: Internal compiler error: program cc1 got fatal signal 6
make[3]: *** [calcPerform.o] Error 1
Cant build EPICS for power pc 40x Chris Timossi
Prev: Cant build EPICS for power pc 40x Chris Timossi
Next: Question about length of PV names Gavin Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
