I'm trying to make a deployable, STATIC build of a soft IOC application for Linux. In base 3.14.7 I edited configure/CONFIG to use STATIC=YES. Then I made an 'example' application using makeBaseApp.pl -t , then again with -i -t. Finally, I copied the app directory to another Linux computer, which doesn't have base. When I start the soft IOC task, AND when the database has an INP field linked to a separate IOC, I get the warning "The executable "caRepeater" couldn't be located", about a minute later the IOC console displays "CA client library is unable to contact CA repeater after 50 tries.", then no more errors. All the while the record with the INP link is working. Other than copying the base/bin and lib dirs to the target machine and incorporating their paths, is there a method to get the caRepeater (et al) included in the application's bin/lib? My old vxWorks IOC's have the caRepeater task bundled in (somehow). Thanks, -- Paul Sichta Princeton Plasma Physics Laboratory 609-243-3477 FAX 3030
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
