1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Motor Record Simulation
To: "Norbury, MA (Martin)" <[email protected]>, <[email protected]>
Date: Wed, 2 Feb 2005 19:00:55 -0600
Title: Message
Dear Martin,
The motor record has "soft motor" device support.  You can give it input and output links (for readback position, drive, stop, etc.).  With a small database that could be used for some simulation.
Mark Rivers
-----Original Message-----
From: Norbury, MA (Martin) [mailto:[email protected]]
Sent: Wednesday, February 02, 2005 8:57 AM
To: [email protected]
Subject: Motor Record Simulation
I was wondering if anybody has considered writing or has written device support for the motor record to simulate a motor. At Diamond a Java user interface is being developed which will talk directly to EPICS motor records. At the moment I've produced a simulation using a combination of EPICS records and SNL code. However, the simulated database and the real database end up being significantly different - which defeats the point of the simulation. A better approach would be to have a simulated device support for the motor record where the type of motor (e.g. steps per rev etc...) can be specified in the st.cmd file.
Any thoughts or help would be greatly appreciated.
Dr Martin Norbury
Software Engineer Beamline Systems
Diamond Light Source Ltd.
Rutherford Appleton Laboratory
Chilton, Didcot.
Oxon
OX11 0QX
Tel: 44 (0) 1235 778235
Prev: Re: DeltaTau PCI Motor Control Boards and Linux Zhijian Yin (ZY)
Next: R3.14.7 next build error ?! Zoltan Kakucs
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Motor Record Simulation Norbury, MA (Martin)
Next: PCaPAC 2005 Workshop Notice Deborah Quock
