1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Initial STAT and SEVR for soft ai and ao records
To: "Bernhard Kuner" <[email protected]>, <[email protected]>
Date: Wed, 2 Feb 2005 07:21:00 -0600
> And why not setting PINI=Yes to say this record is processed and ready
> to use and keep the one thing for all records in mind that:  a record
is
> undefined and invalid until it is processed! This behaviour is
> neccessary for all records with hardware access and to start all
records
> this way keeps from beeing puzzled about what state any particular
> record should be have after the start of an ioc because it is UDF
INVALID.
Saying PINI=Yes is not "saying this record is processed", it actually
processes the record.  That can have major side-effects, if it has PP or
CP links to other records.
I understand what you are saying about records with hardware access.  My
argument is that records with soft device support and constant links
already initialize with UDF=0, but they have STAT=UDF.  I don't see a
reason why such a soft record needs to process, but I realize that
changing this now is probably not practical.
Re: Initial STAT and SEVR for soft ai and ao records Bernhard Kuner
Prev: Re: Initial STAT and SEVR for soft ai and ao records Bernhard Kuner
Next: R3.14.7 build error Zoltan Kakucs
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Initial STAT and SEVR for soft ai and ao records Mark Rivers
Next: Re: Initial STAT and SEVR for soft ai and ao records Bernhard Kuner
