1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Initial STAT and SEVR for soft ai and ao records
To: <[email protected]>
Date: Tue, 1 Feb 2005 13:10:35 -0600
Folks,
There is something I don't quite understand about the ao and ai records with soft device support.
If I set DOL="1", then the init_record routine, either in the record (for ao), or in device support (for ai) sets prec->udf=0.  This is what I expect.  However, I find that after iocInit that STAT=UDF and SEVR=Invalid.  This is not what I expected.
The records never call checkAlarms in init_record, so the STAT and SEVR are not being reset to NO_ALARM.  Are the STAT and SEVR fields to to UDF and INVALID somewhere else in base before init_record is called?
If I set PINI=1 in my database, then the record will process once, and STAT and SEVR will be set to NO_ALARM.  But I don't understand why I have to do this, why does a soft record initialize with STAT=UDF aand SEVR=Invalid when its DOL is OK?
Is this the desired behavior, and is there a way to make the STAT and SEVR be NO_ALARM without having to set PINI=1?
Re: Initial STAT and SEVR for soft ai and ao records Marty Kraimer
Prev: RE: DeltaTau PCI Motor Control Boards and Linux Norbury, MA (Martin)
Next: Re: Initial STAT and SEVR for soft ai and ao records Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
