An up to date version of the code for the tty driver is attached.
The version at Delta site is slightly out of date.
Pete
> I have developped the Stream Device driver to talk to a lot of
> serial/GPIB/... devices. I also have a protocol file for the Danfysik
> 8000 PS. You probably need a driver interface for your serial
> board to
> Stream Device (Stream Device itself is hardware independent).
> Pete Owens
> from Diamond has written one. Look at
> www.delta.uni-dortmund.de/controls. Pete's tty driver is in
> the download
> area under unsupported.
> I have attached the protocol file and the template I used at
> DELTA. Try
> this as a starting point.
> Dirk.
> Gournay Jean-Francois wrote:
> > Hello all,
> > I have to talk to the magnet power supply system 8000 from O.D.
> > Not surprisingly the controller has a clumsy protocol over
> a serial line.
> > After spending some time to fight with it, I am wondering
> if somebody
> > has already developed something for it ?
> > If no, perhaps somebody can make some suggestions ...
> > 1. Some commands give responses, some other not ... but drvAscii /
> > drvSerial seems OK to accomodate this. What is not so nice
> is that I
> > have a semTake error due to the timeout (the PS is connect
> to a vxWorks
> > serial port and I am with R3.13) when I have no response
> from the PS
> > which means no error !!! But OK I can live with this.
> > 2. The most difficult problem I have is the following : I
> have to write
> > DAC values with a string which looks like : <WA 999999>
> (999999 is an
> > integer value with 6 digits). This command gives a response
> in a string.
> > I tried to implement this with an ao record with a flnk to
> a sub record
> > and finally with a stringin record which talks to the PS.
> The idea is to
> > modify the INP field of the stringin record in
> psDACProcess, to reflect
> > the desired DAC value.
> > The DB looks like this :
> > record(ao, "PS_DAC_OUT_ao") {
> > field(FLNK,"PS_DAC_sb")
> > record(sub,"PS_DAC_sb") {
> > field(INAM,"psDACInit")
> > field(SNAM,"psDACProcess")
> > record(stringin, "PS_DAC_OUT_si") {
> > field(DESC,"PS DAC output I")
> > field(DTYP,"Ascii SIO")
> > field(INP,"@/tyCo/2 <WA 999999><%s>")
> > The sub record works and I am able to reflect the desired
> value coming
> > from the ao record in the INP field of the stringin record.
> > The problem is that the INP field of the stringin record is
> stored by
> > devAscii at the init of the record and any subsequent changes are
> > ignored when the record is processed.
> > Thans for any help.
> > Jean-François
> > J.F. Gournay
> > CEA Saclay
> > DAPNIA/SIS
> > tel +33 (0)1 69 08 70 32
> > fax +33 (0)1 69 08 63 01
> Dr. Dirk Zimoch
> Swiss Light Source
> Paul Scherrer Institut
> Computing and Controls
> phone +41 56 310 5182
> fax +41 56 310 4413
streamTty.c
Description: streamTty.c
Re: Oxford/Danfysik power supply Dirk Zimoch
RE: Oxford/Danfysik power supply Elder Matias
<2005>
<2005>
