I have developped the Stream Device driver to talk to a lot of serial/GPIB/... devices. I also have a protocol file for the Danfysik 8000 PS. You probably need a driver interface for your serial board to Stream Device (Stream Device itself is hardware independent). Pete Owens from Diamond has written one. Look at www.delta.uni-dortmund.de/controls. Pete's tty driver is in the download area under unsupported. I have attached the protocol file and the template I used at DELTA. Try this as a starting point. Dirk. Gournay Jean-Francois wrote: Hello all,
# Danfysik Netzgeraet fuer Solenoiden outTerminator = CR; inTerminator = LF CR; ReplyTimeout=2000; ReadTimeout=500; command { out "%s"; } info { out "%s"; in "%39c"; } reset { out "RS"; } current { out "AD 8"; in "%d"; } # 1E-3 A current.set { out "WA %05d"; } # 1E-3 A current.rb { out "RA"; in "%d"; } # 1E-4 A ExtraInput = ignore; switch { out "S1"; in "%{!|.}"; } switch.set { out "%{F|N}"; } interlock.sum { in "%*9c%{.|!}"; } interlock.overcurrent { in "%*10c%{.|!}"; } interlock.overload { in "%*11c%{.|!}"; } interlock.regmodule { in "%*12c%{.|!}"; } interlock.preregul { in "%*13c%{.|!}"; } interlock.phase { in "%*14c%{.|!}"; } interlock.mpswater { in "%*15c%{.|!}"; } interlock.earth { in "%*16c%{.|!}"; } interlock.fuse { in "%*17c%{.|!}"; } interlock.mpstemp { in "%*18c%{.|!}"; } interlock.panicbutton { in "%*19c%{.|!}"; } interlock.magnetwater { in "%*20c%{.|!}"; } interlock.magnettemp { in "%*21c%{.|!}"; } interlock.mpsready { in "%*22c%{!|.}"; } # Macros: NAME BUS DESC SCAN_PERIOD record (ai, "$(NAME)-i") { field (DESC, "$(DESC) current") field (DTYP, "stream") field (INP, "@Danfysik-8000 current $(BUS)") field (SCAN, "$(SCAN_PERIOD)") field (LINR, "LINEAR") field (EGU, "A") field (LOPR, "0") field (HOPR, "99.999") field (PREC, "3") field (EGUF, "100") field (EGUL, "0") field (ESLO, "1e-3") field (FLNK, "$(NAME)-i:comp") field (PRIO, "HIGH") } record (ao, "$(NAME)-i:set") { field (DESC, "$(DESC) current") field (DTYP, "stream") field (OUT, "@Danfysik-8000 current.set $(BUS)") field (LINR, "LINEAR") field (EGU, "A") field (LOPR, "0") field (HOPR, "99.999") field (PREC, "3") field (DRVL, "0") field (DRVH, "99.999") field (EGUF, "100") field (EGUL, "0") field (ESLO, "1e-3") } record (ai, "$(NAME)-i:rb") { field (DESC, "$(DESC) current") field (DTYP, "stream") field (INP, "@Danfysik-8000 current.rb $(BUS)") field (SCAN, "$(SCAN_PERIOD)") field (LINR, "LINEAR") field (EGU, "A") field (LOPR, "0") field (HOPR, "99.999") field (PREC, "3") field (EGUF, "100") field (EGUL, "0") field (ESLO, "1e-4") field (PRIO, "HIGH") } record (bo, "$(NAME):reset") { field (DESC, "$(DESC) reset") field (DTYP, "stream") field (OUT, "@Danfysik-8000 reset $(BUS)") field (SEVR, "NO_ALARM") } record (bo, "$(NAME)-sw:set") { field (DESC, "$(DESC) switch") field (DTYP, "stream") field (OUT, "@Danfysik-8000 switch.set $(BUS)") field (ZNAM, "OFF") field (ONAM, "ON") } record (bi, "$(NAME)-sw") { field (DESC, "$(DESC) switch") field (SCAN, "$(SCAN_PERIOD)") field (DTYP, "stream") field (INP, "@Danfysik-8000 switch $(BUS)") field (ZNAM, "OFF") field (ONAM, "ON") field (PRIO, "HIGH") } record (bi, "$(NAME)-ilock") { field (DESC, "$(DESC) switch") field (SCAN, "I/O Intr") field (DTYP, "stream") field (INP, "@Danfysik-8000 interlock.sum $(BUS)") field (ZNAM, "OK") field (ONAM, "ERROR") field (PRIO, "HIGH") } record (bi, "$(NAME)-ilock-water") { field (DESC, "$(DESC) switch") field (SCAN, "I/O Intr") field (DTYP, "stream") field (INP, "@Danfysik-8000 interlock.magnetwater $(BUS)") field (ZNAM, "OK") field (ONAM, "ERROR") field (PRIO, "HIGH") } record (bi, "$(NAME)-ilock-fuse") { field (DESC, "$(DESC) switch") field (SCAN, "I/O Intr") field (DTYP, "stream") field (INP, "@Danfysik-8000 interlock.fuse $(BUS)") field (ZNAM, "OK") field (ONAM, "ERROR") field (PRIO, "HIGH") } record (bi, "$(NAME)-ilock-earth") { field (DESC, "$(DESC) switch") field (SCAN, "I/O Intr") field (DTYP, "stream") field (INP, "@Danfysik-8000 interlock.earth $(BUS)") field (ZNAM, "OK") field (ONAM, "ERROR") field (PRIO, "HIGH") } record (bi, "$(NAME)-ilock-overload") { field (DESC, "$(DESC) switch") field (SCAN, "I/O Intr") field (DTYP, "stream") field (INP, "@Danfysik-8000 interlock.overload $(BUS)") field (ZNAM, "OK") field (ONAM, "ERROR") field (PRIO, "HIGH") } record (bi, "$(NAME)-ilock-temp") { field (DESC, "$(DESC) switch") field (SCAN, "I/O Intr") field (DTYP, "stream") field (INP, "@Danfysik-8000 interlock.magnettemp $(BUS)") field (ZNAM, "OK") field (ONAM, "ERROR") field (PRIO, "HIGH") } record (bi, "$(NAME)-ilock-ready") { field (DESC, "$(DESC) switch") field (SCAN, "I/O Intr") field (DTYP, "stream") field (INP, "@Danfysik-8000 interlock.mpsready $(BUS)") field (ZNAM, "NO") field (ONAM, "YES") field (PRIO, "HIGH") } # status records record (ao, "$(NAME)-i:setup") { field (EGU, "A") } record (calc, "$(NAME)-setup:comp") { field (DESC, "compare value and setup") field (INPA, "$(NAME)-i") field (INPB, "$(NAME)-i:setup") # Max. allowed absolute and relative setup<->read difference field (INPC, "0.2") field (INPD, "0.01") field (CALC, "ABS(A-B)<C || ABS(A-B)/(ABS(A)+0.001)<D") field (LOW, "0" ) field (LSV, "MAJOR") } record (calc, "$(NAME)-i:comp") { field (DESC, "$(DESC) compare") field (INPA, "$(NAME)-i") field (INPB, "$(NAME)-i:set") # Max. allowed absolute and relative set<->read difference field (INPC, "0.2") field (INPD, "0.01") field (CALC, "ABS(A-B)<C || ABS(A-B)/(ABS(A)+0.001)<D") field (LOW, "0" ) field (LSV, "MAJOR") } #initialization record (ai, "$(NAME)-i:init") { field (DESC, "$(DESC) current") field (DTYP, "stream") field (INP, "@Danfysik-8000 current.rb $(BUS)") field (PINI, "YES") field (LINR, "LINEAR") field (EGU, "A") field (LOPR, "0") field (HOPR, "99.999") field (PREC, "3") field (EGUF, "100") field (EGUL, "0") field (ESLO, "1e-4") field (PRIO, "HIGH") field (FLNK, "$(NAME)-i:copy") } record (ao, "$(NAME)-i:copy") { field (DESC, "$(DESC) current") field (DOL, "$(NAME)-i:init MS") field (OUT, "$(NAME)-i:set PP") field (OMSL, "closed_loop") field (IVOA, "Don't drive outputs") field (EGU, "A") field (HOPR, "99.999") field (PREC, "3") field (FLNK, "$(NAME)-sw:init") } record (bi, "$(NAME)-sw:init") { field (DESC, "$(DESC) switch") field (DTYP, "stream") field (INP, "@Danfysik-8000 switch $(BUS)") field (ZNAM, "OFF") field (ONAM, "ON") field (PRIO, "HIGH") field (FLNK, "$(NAME)-sw:copy") } record (bo, "$(NAME)-sw:copy") { field (DESC, "$(DESC) switch") field (DOL, "$(NAME)-sw:init MS") field (OUT, "$(NAME)-sw:set PP") field (OMSL, "closed_loop") field (IVOA, "Don't drive outputs") field (ZNAM, "OFF") field (ONAM, "ON") } # debug records record (stringout, "$(NAME):command") { field (DESC, "- $(DESC) debug -") field (DTYP, "stream") field (OUT, "@Danfysik-8000 command $(BUS)") } record (stringout, "$(NAME):info") { field (DESC, "- $(DESC) debug -") field (DTYP, "stream") field (OUT, "@Danfysik-8000 info $(BUS)") }
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
