Is it less confusing if EPICS/vxWorks, EPICS/RTEMS and EPICS/other O.S.
can unify this implementation ? Perhaps, the vxWorks implementation
could be helpful, although could'nt be ideal ? I do not have vxWorks for
3.14 to verify this. However, here is some of my thoughts, hoping to
hear others.
1) Could the vxWorks implementation be ported to the RTEMS as a default ?
Perhaps, that function could be turned off as an option, although not safe,
in case of demanding application assuming the users have absloutely
knowledge and control of the client access of the IOC
Jeff Hill Wrote :
>It would of course also help to allocate *all* memory off of free lists,
> but this is not easy especially with any approach to variable length strings
> that requires contiguous storage.
2) How about at least for the array and waveform (e.g. image processing) ?
Is it easy ?
Kate
- Re: CA Connect rates under RTEMS (vxWorks, too) Eric Norum
- RE: CA Connect rates under RTEMS (vxWorks, too) Jeff Hill
- CA Connect rates under RTEMS wnolan
- Re: CA Connect rates under RTEMS Eric Norum
Re: CA Connect rates under RTEMS Till Straumann
<2005>
RE: CA Connect rates under RTEMS Jeff Hill
<2005>
