1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Porting db file generation from 3.13 to 3.14
To: [email protected]
Date: Tue, 21 Dec 2004 13:16:10 +0100
I'm in the early stages of porting a 3.13 application to 3.14 and got
stuck almost immediately.
Our typical application creates X.db using X.substitutions and template
files a.template and b.template. X.substitutions looks like this
file a.template {
  { NAME="a1" }
  { NAME="a2" }
file b.template {
  { NAME="b1" }
  { NAME="b2" }
  { NAME="b3" }
In my old (3.13) Makefile.Host I have
USES_TEMPLATE = a.template b.template
DB = X.db
which creates X.db by calling (more or less)
msi -S X.substitutions > X.db
That is, msi is used as substitution for host side dbLoadTemplate.
What definitions do I need in my Makefile to make this work in 3.14?
Make complains about a missing "../X.template".
I read chapter 4 of the ADG but there is no clue to what I should do
here. The doc seems to suggest that expanding substitutions files in
the dbLoadTemplate style is no longer supported because it seems that
*one* template file is required for each substitution file and a subst
files like the above obviously needs not one but many different
template files.
Almost all of our applications use above style to expand db on the host
side and most of the substitutions files are generated by scripts from
a relational Database.
I am quite astonished that I seem to be the first one stumbling over
this. Any suggestion on how to proceed would be greatly appreciated.
Ben
Prev: Re: Micos Motor Support query. David Maden
Next: Has anyone built EDM for OS X? Josh Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: database conversion john sinclair
