For R3.14.6, ai record, the following: What device support are you using for this record? Some device support layers set LINR to 0 because they will write their input values directly to the VAL field without doing any input conversions at all. Poking a 2 into LINR seems to make the record aware of the ESLO field.> Can anyone explain this. I've read the record manual but am still not certain of the correct value for the LINR field. LINR is a menu field, the definition of menuConvert is found in <base>/src/bpt/menuConvert.dbd (and gets installed into <base>/dbd) but may be overridden by your IOC application if it needs to load any other breakpoint tables. -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
