1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Index of highest value
Cc: [email protected]
Date: Mon, 20 Dec 2004 12:20:53 -0500
Andrew Johnson wrote:
How about creating your own modified version of the SEL record with slight modification to the code: In the calculation for SELECT_HIGH (and probably for SELECT_LOW as well for symmetry) have it set psel->seln=i as well as recording the highest value. Then you can read the SELN field to find the index you want.
We probably ought to make this change in the Base version of the selRecord as it seems like a common kind of issue, but I don't know how many existing databases it might break so I'd welcome any feedback positive or negative on the suggestion.
Technically, that seems like an ideal solution to my particular application. It is simple
to implement, is logically consistent with the SEL record behavior, completely solves
my problem (e.g. I don't need a monitor on SELN), and is unlikely to be incompatible
with existing use.
Sociology is another issue..... It seems unlikely to me that your suggestion would
break anything but the most contrived and non-mainstream application. However,
the larger the user base, the more likely contrived and non-mainstream applications
become!
Once can certainly avoid breaking legacy application by introducing yet more
mode selections (e.g. "High Signal Index"), while leaving the behavior of existing
mode selections unchanged. However, that could lead to unecessary, and potentially
confusing "mode creep".
I suppose big, bold warnings in EPICS release notes should be sufficient to
warn users of new record functionality that comes with new versions of EPICS,
especially if they come with guidance on how to work around new functionality
which "breaks" existing applications. I do wonder if anyone ever really reads
release notes before they commit to an upgrade, though........
I could make my own record for my own application, but that seems a rather
heavy-handed approach, especially since I can use a group of CALC records
or a single SUBROUTINE record, and not incur the maintenance burden of
a new record (which has 99% functionality overlap with the SEL record).
I look forward to watching the "social side" of how this issue plays out.
Meanwhile, I find that by pairing each of my "goodness" ao records with a
calc record, and using two SEL records, I can implement my application
in a understandable (IMHO) way, so the issue has become moot. If your
proposed functionality becomes available, all those CALC records and one
SEL record would become unecessary.
-- Larry
Index of highest value Lawrence T. Hoff
Re: Index of highest value Andrew Johnson
Prev: Re: Index of highest value Andrew Johnson
Next: Re: EPICS VLINAC demo on MacOS X (darwin) Steve Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Index of highest value Tim Mooney
