Lawrence T. Hoff wrote: ... I.e. I realize that I can find the highest "goodness factor" via a SEL record. As far as I know, that can provide the highest value, but not which input that value came form. Good point/problem. Suggestions? How about creating your own modified version of the SEL record with slight modification to the code: In the calculation for SELECT_HIGH (and probably for SELECT_LOW as well for symmetry) have it set psel->seln=i as well as recording the highest value. Then you can read the SELN field to find the index you want. We probably ought to make this change in the Base version of the selRecord as it seems like a common kind of issue, but I don't know how many existing databases it might break so I'd welcome any feedback positive or negative on the suggestion. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
