1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: antelope on Solaris 9
To: Paul Sichta <[email protected]>
Cc: [email protected]
Date: Thu, 16 Dec 2004 13:54:36 -0600
Paul Sichta wrote:
I had some difficulty compiling R3.14.7 on Solaris 9 with SunStudio 9.
Is this a build issue that others have had on Solaris 9, or did I miss the more elegant solution?
Appologies about the default setting there. If you don't have readline installed and you don't want to install it, you should be able to just comment out the COMMANDLINE_LIBRARY setting in your file
<base>/configure/os/CONFIG_SITE.Common.solaris-sparc
The next release will default to this being commented out.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
antelope on Solaris 9 Paul Sichta
Prev: antelope on Solaris 9 Paul Sichta
Next: IPAC Version 2.8 released Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
