1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: problem about Channel Archiver
To: 黄松 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 30 Nov 2004 09:09:02 +0100
Hallo 黄松:
After reboot an EPICS database all records are STAT=INVALID, UDF=1.
First Processing of the record will reset the UDF field to 0 and set
STAT to the status that matches the result of the processing - NO_ALARM
if no bad things happen. Your ao-record is an OUT record, so it is ok if
it is UDF INVALID, as long as nobody wrote something to it.
Another point is to initialize it to a reasonable start value - this is
an old EPICS problem, because OUT records have no link field to be
initialized after reboot from another record that provides a readback of
the hardware. If there is any hardware to readback the
"TC:PS:B1:AI1:current" it is Your turn to set your ao-record to this
value after reboot of the IOC.
best regards
Bernhard Kuner
problem about Channel Archiver 黄松
Prev: problem about Channel Archiver 黄松
Next: RE: problem about Channel Archiver Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
