1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem building EPICS Base 3.14.6 on Fedora Core 3
To: [email protected]
Date: Thu, 25 Nov 2004 15:03:16 +0100
Hi all,
It seems, that changing lines in udpiiu.h works, but then I get this error. Is there any workaround for this also?
Thanks
Iztok
Installing generic include file ../../../include/caDiagnostics.h
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -
ansi -O3 -Wall -I. -I.. -I../../../include/os/Linux -I../../../include ../catime.c
ansi -O3 -Wall -I. -I.. -I../../../include/os/Linux -I../../../include ../acctst.c
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -
ansi -O3 -Wall -I. -I.. -I../../../include/os/Linux -I../../../include ../caConnTest.cpp
ansi -O3 -Wall -I. -I.. -I../../../include/os/Linux -I../../../include ../casw.cpp
ansi -O3 -Wall -I. -I.. -I../../../include/os/Linux -I../../../include ../caEventRate.cpp
ansi -O3 -Wall -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include ../cac.cpp
In file included from ../cac.h:52,
from ../cac.cpp:35:
../virtualCircuit.h:72: error: `virtual void tcpRecvThread::run()' is private
../virtualCircuit.h:290: error: within this context
../virtualCircuit.h:73: error: `void tcpRecvThread::connect()' is private
../virtualCircuit.h:291: error: within this context
make[3]: *** [cac.o] Error 1
RE: Problem building EPICS Base 3.14.6 on Fedora Core 3 Jeff Hill
Prev: Modbus/TCP for Linux Paul Sichta
Next: RE: Modbus/TCP for Linux[Scanned] Terry Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Problem building EPICS Base 3.14.6 on Fedora Core 3 Jeff Hill
Next: RE: Problem building EPICS Base 3.14.6 on Fedora Core 3 Jeff Hill
