> > Is there a fix?
> No.
One possible short term fix would be to add a new DBR_XXX type similar to
DBR_GR_ENUM, but with more states. This would require changes in database
access but would have a relatively low impact on CA.
A more general approach is in progress based on data access.
Jeff
> -----Original Message-----
> From: Marty Kraimer [mailto:[email protected]]
> Sent: Tuesday, November 23, 2004 6:13 AM
> To: Dirk Zimoch
> Cc: TECHTALK
> Subject: Re: only 16 enum states?
> Dirk Zimoch wrote:
> > Hi all,
> > when I try to read the choices of an enum field, I only get the first
> > 16. This ist not enough to read all the choices of the LINR field
> > (menuConvert) if there are many breakpoint tables. It's even not
> > enough to read all choices of the STAT field.
> As you found out it is a problem in db_access.h, which describes that
> data that passes through Channel Access.
> > Is there a fix?
> No.
> > What happens if I change in db_access.h
> > #define MAX_ENUM_STATES 16
> > in
> > #define MAX_ENUM_STATES 255
> You will break any existing CA client and server that uses ENUMs
> > Dirk
> Perhaps Bob Dalesio can make a few comments about how we plan to address
> this and other known problems created by db_access.h. For example
> strings are limited to 40 characters. We hope to start addressing these
> issues in the near future.
- Re: only 16 enum states? Marty Kraimer
RE:Thales RF transmitter controls Elder Matias
RE: Thales RF transmitter controls Gurd, Pamela A.
<2004>
RE: only 16 enum states? Dalesio, Leo
<2004>
