This is one of several limitations that have existed from the start. We have a preliminary plan that we will present at the meeting at KEK. The short answer to handling this as well as the limited string length problem is that we plan to do it in version 4. This is 2 years away according to the plan. It requires at least a rewrite of the database access layer.
Bob
-----Original Message-----
Sent: Tuesday, November 23, 2004 5:13 AM
To: Dirk Zimoch
Cc: TECHTALK
Subject: Re: only 16 enum states?
Dirk Zimoch wrote:
> Hi all,
> when I try to read the choices of an enum field, I only get the first
> 16. This ist not enough to read all the choices of the LINR field
> (menuConvert) if there are many breakpoint tables. It's even not
> enough to read all choices of the STAT field.
As you found out it is a problem in db_access.h, which describes that
data that passes through Channel Access.
> Is there a fix?
No.
> What happens if I change in db_access.h
> #define MAX_ENUM_STATES 16
> in
> #define MAX_ENUM_STATES 255
You will break any existing CA client and server that uses ENUMs
> Dirk
Perhaps Bob Dalesio can make a few comments about how we plan to address
this and other known problems created by db_access.h. For example
strings are limited to 40 characters. We hope to start addressing these
issues in the near future.
Re: only 16 enum states? Marty Kraimer
RE: only 16 enum states? Liyu, Andrei
<2004>
RE: only 16 enum states? Jeff Hill
<2004>
