Andrew
>From my tests, the problem arises as a result of compiling for a PPC-based
IOC using:
1. The compiler supplied by Windriver to build on a Solaris host for Tornado
2.2.1, i.e. vxWorks 5.5.1,
2. The gcc 2.9.6 compiler provided by Dave Thompson to build on a Linux host
for the same target.
It does not arise as a result of compiling for a PPC-based IOC using:
2.0.2, i.e. vxWorks 5.4.2,
2. The gcc 2.7.2 compiler provided by Dave Thompson to build on a Linux host
We do not use 68K on Diamond so I cannot comment on compilers for that
processor.
Regards
Steve
-----Original Message-----
[mailto:[email protected]]On Behalf Of Andrew Johnson
Sent: 18 November 2004 17:25
To: Thompson, David H.
Cc: EPICS tech-talk
Subject: Re: calc and calcout records in EPICS 3.14.6
Thompson, David H. wrote:
> Question:
> Are you saying that this problem exists in the gcc 2.7.2 compiler AND
> the 2.9.6 (vxWorks 5.5.x) compiler for both the 68K and PPC?
I understood that what WRS shiped for Tornado 2.x was a mixture of two
compilers - the C front end from gcc-2.7.2 (to retain backwards
compatibility of the object files with earlier versions of vxWorks), and
the C++ front end from EGCS (to get updated C++ support).
This optimizer problem has only been noticed on the 68K target, and not
just in compiler versions built from the GCC sources you provide - my
official WRS Tornado 2.0.2 compiler does exactly the same thing.
I confirmed Ron Sliuter's report about the code generated for
epicsThreadSleepQuantum(), which is actually a very simple routine.
Here's the complete test file that generates the error:
#include <vxWorks.h>
#include <stdio.h>
#include <sysLib.h>
#ifdef __cplusplus
#define EXPORT extern "C"
#else
#define EXPORT
#endif
EXPORT double bug();
/* Tornado compilers for 68k have an optimizer bug at -O1 and above; the
* code generated for bug() is incorrect. The vxWorksBrokenCompilerTest
* routine tests for that bug, and must appear above the code it calls or
* or the optimizer may inline epicsThreadSleepQuantum() */
EXPORT int vxWorksBrokenCompilerTest()
double tick = bug();
double one = tick * (double) sysClkRateGet();
int ok = (one > 0.999) && (one < 1.001);
printf("%s: bug() = %f\n", ok ? "Ok" : "BROKEN", tick);
return ok;
EXPORT double bug()
double HZ = (double) sysClkRateGet();
return 1.0 / HZ;
This is the code I get for the bug() routine using -O3:
bug:
ada916 4856 PEA (A6)
ada918 2c4f MOVEA .L A7,A6
ada91a 61ff ff54 57fc BSR sysClkRateGet
ada920 203c 3ff0 0000 MOVE .L #0x3ff00000,D0
ada926 7200 MOVEQ #0,D1
ada928 2f01 MOVE .L D1,-(A7)
ada92a 2f00 MOVE .L D0,-(A7)
ada92c f21f 5444 FDMOVE.D (A7)+,F0
ada930 f200 4064 FDDIV .L D0,F0
ada934 f227 7400 FMOVE .D F0,-(A7)
ada938 201f MOVE .L (A7)+,D0
ada93a 221f MOVE .L (A7)+,D1
ada93c 4e5e UNLK A6
ada93e 4e75 RTS
Note how in the 4th instruction above, the value from the call to
sysClkRateGet() which was returned in D0 gets trashed by the constant 1.0
value being pushed onto the stack.
Using -O0, the code generated is this:
bug:
adbfbe 4e56 fff8 LINK .W A6,#0xfff8
adbfc2 61ff ff54 4154 BSR sysClkRateGet
adbfc8 f200 40c4 FDMOVE.L D0,F1
adbfcc f22e 7480 fff8 FMOVE .D F1,(0xfff8,A6)
adbfd2 f23a 5444 ffe0 FDMOVE.D (0xffe0,PC),F0
adbfd8 f22e 5464 fff8 FDDIV .D (0xfff8,A6),F0
adbfde f227 7400 FMOVE .D F0,-(A7)
adbfe2 201f MOVE .L (A7)+,D0
adbfe4 221f MOVE .L (A7)+,D1
adbfe6 6000 0002 BRA 0x00adbfea
adbfea 4e5e UNLK A6
adbfec 4e75 RTS
> And are
> you also saying that the c++ compiler is not affected? Have you tested
> this or have experience that confirms this?
I thought that was the case, but I was wrong; the identical code gets
generated whether I build the source file as C or C++ (and I know it's
getting compiled as C++ code because I had to add the export "C" macro).
Therefor I'm going to have to turn off the optimizer for C++ code as well.
This is very bad news for R3.14 on 68K until we get a compiler fix...
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night. That was really cool. - Caro
- Re: VxWorks compiler optimization issues, Was: calc and calcout records in EPICS 3.14.6 Steven Hartman
Epics assert fail Michael Abbott
<2004>
Re: calc and calcout records in EPICS 3.14.6 Andrew Johnson
<2004>
