1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem building epics base-3.14.6 with recent gcc on linux
To: tech-talk <[email protected]>
Date: Fri, 19 Nov 2004 02:19:12 -0500
Hi Ernest,
So the gcc version was not the issue, the problem was that I did not have the readline-devel package installed on my linux system by default.
On my Fedora Core 1 system I had readline and readline-devel version 4.3.7 installed by default. On my Ubuntu (debian based) system I had libreadline4 4.3-11 installed by default, after installing the libreadline4-dev 4.3-11 package I was able to successfully build epics base.
Chip
I am not sure where to find information about a full list of requirements to build on various platforms. I think it may just be assumed that the readline and readline-devel packages are installed on most Linux systems by default. But I am just guessing.
That is true especially for Red Hat. I have not seen this problem. Chip what flavor of Linux are you using?
I have tested the build on RH Enterprise Linux as well as Fedora Core
Release 3 with success
gcc version 3.4.2 20041017 (Red Hat 3.4.2-6.fc3)
Problem building epics base-3.14.6 with recent gcc on linux Chip Piller
Re: Problem building epics base-3.14.6 with recent gcc on linux Robert Soliday
Re: Problem building epics base-3.14.6 with recent gcc on linux Chip Piller
Re: Problem building epics base-3.14.6 with recent gcc on linux Ernest L. Williams Jr.
Prev: Canot write PVs when restore snapshot using burtwb 胡勇
Next: Epics assert fail Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem building epics base-3.14.6 with recent gcc on linux Ernest L. Williams Jr.
Next: Canot write PVs when restore snapshot using burtwb 胡勇
