hi
In our application, we try to use BURT to backup and
restore IOC PVs' setting. Everything is OK when we backup the
PVs with burtrb. But when we use burtwb to restore the values, it
cannot write the PV at all. We checked the
burtwb logfile, it indicates all values successfully written.
When we use ca_test to access these PVs, it works well.
We didnot use BURT before, I will appreciate it
very much if someone can give me some instructions or proposals?
Thanks for your help.
request file:
# Power Supply Database PV backup reguest file # DING Jianguo, SSRF # firstly created: 2004/11/8 ######################################################################## # ding:aoExample
Snapshot file:
--- Start BURT header Time: Mon Nov 15 21:32:11 2004 Login ID: linac () Eff UID: 501 Group ID: 501 Keywords: Comments: Type: Absolute Directory /control/epicsApp/dingtest/snap Req File: req --- End BURT header ding:aoExample 1 1.300000000000000e+01 Restort Log file:
**** WRITE BURT LOGFILE
--- Start processing snapshot files
file >out1< pv >ding:aoExample< nelem 1 --- End processing snapshot files --- Start reading dependency files
--- End reading dependency files processing all dependency files ... done
--- Start searches
ding:aoExample ... ca_search_and_connect() ... OK --- End searches Waiting for 1 outstanding search(es) ... found all OK --- Start writes
ding:aoExample ... ca_array_put() nelem 1 ... OK flushing with ca_flush_io() ... OK --- End writes did not find any read only notify values ... NO OUTPUT FILE
CREATED
**** END BURT LOGFILE
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
