Hi, I've tried to build epics base-3.14.6 on linux, results are: gcc 3.3.2: Success. gcc 3.3.4: Failed for both 3.14.6 and latest CVS. gcc 3.4.2: Failed for both 3.14.6 and latest CVS. Any info/suggestions for using recent gcc? Thanks, Chip Piller =========================== Output from failed build: -I../../../include ../../../src/libCom/osi/os/default/epicsReadline.c ../../../src/libCom/osi/os/default/epicsReadline.c:77:31: readline/readline.h: No such file or directory ../../../src/libCom/osi/os/default/epicsReadline.c:78:30: readline/history.h: No such file or directory ../../../src/libCom/osi/os/default/epicsReadline.c: In function `epicsReadlineBegin': ../../../src/libCom/osi/os/default/epicsReadline.c:102: warning: implicit declaration of function `stifle_history' ../../../src/libCom/osi/os/default/epicsReadline.c:103: warning: implicit declaration of function `rl_bind_key' ../../../src/libCom/osi/os/default/epicsReadline.c:103: error: `rl_insert' undeclared (first use in this function) ../../../src/libCom/osi/os/default/epicsReadline.c:103: error: (Each undeclared identifier is reported only once ../../../src/libCom/osi/os/default/epicsReadline.c:103: error: for each function it appears in.) ../../../src/libCom/osi/os/default/epicsReadline.c: In function `epicsReadline':../../../src/libCom/osi/os/default/epicsReadline.c:125: warning: implicit declaration of function `readline' ../../../src/libCom/osi/os/default/epicsReadline.c:125: warning: assignment makes pointer from integer without a cast ../../../src/libCom/osi/os/default/epicsReadline.c:163: warning: implicit declaration of function `add_history' make[3]: *** [epicsReadline.o] Error 1 make[3]: Leaving directory `/home/piller/epics/base-3.14.6/src/libCom/O.linux-x86' make[2]: *** [install.linux-x86] Error 2 make[2]: Leaving directory `/home/piller/epics/base-3.14.6/src/libCom' make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory `/home/piller/epics/base-3.14.6/src' make: *** [src.install] Error 2 piller@piller64 ~/epics/base-3.14.6 $
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
