1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: calc and calcout records in EPICS 3.14.6
Cc: Andrew Johnson <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 17 Nov 2004 08:51:08 -0600
I reported a problem with the Tornado 2.2.1 supplied compiler
via the Mantis Bug Reporting mechanism; Bug ID #82.
The jest of the report is that the epicsThreadSleepQuantum() function
returns erroneous values when -O3 optimization is used.
Ron
Mark Rivers wrote:
Andrew and Ralph,
We've been using the SNS versions of PPC and 68K compilers without being
aware of the bugs that Andrew mentioned.  Are these documented somewhere
on the Web?
> There are also problems with a 68K C++ compiler built from these
sources;
> in that case the issue is related to passing bool variables as
arguments
> to functions or member functions - again I haven't chased the
detail.
Plus a problem with NULL pointers being treated wrong in expressions
(after setting a pointer to NULL, comparing it to NULL in an
expression
would yield a FALSE).
Afaik this problem is appeared only in the 68k version of the original
Tornado 2.0.2 compiler and was fixed with a later patch. Anyway:
compilers built from the sources available at SNS are not showing this
bug. (That's why we rebuilt even our HP-UX based compiler from the SNS
sources.)
Re: calc and calcout records in EPICS 3.14.6 Andrew Johnson
RE: calc and calcout records in EPICS 3.14.6 Mark Rivers
Prev: EPICS meeting at KEK Dalesio, Leo
Next: RE: calc and calcout records in EPICS 3.14.6 Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: calc and calcout records in EPICS 3.14.6 Mark Rivers
Next: Re: calc and calcout records in EPICS 3.14.6 Andrew Johnson
