1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Multiple IOC's in a crate?
Cc: W T Meyer <[email protected]>, [email protected]
Date: Tue, 09 Nov 2004 14:47:44 -1000
some much simpler considerations as well:
Andrew Johnson wrote:
W T Meyer wrote:
Is it possible to run two or more IOCs in a single VME crate? At present we're running MVV-177 IOCs running VxWorks, but are considering upgrading.
It is, providing you're careful.
and the crate is local. On a local crate you can of course push the reset button on each board if you want to hard reboot it. If you are far away from your crates (like us, where it's 30 miles) and you put them on remote access power switches to be able to hard boot (power cycle) remotely, those go by power plugs, not by IP addresses, so you can only hard boot the whole thing.
I'm not sure whether the one dual-IOC crate we had here at APS is still in that state, but we certainly have used that approach here in the past.
We sometimes do in the lab, otherwise only for multi-CPU applications (when you know you're only going to power cycle these together).
Maren
Multiple IOC's in a crate? W T Meyer
Re: Multiple IOC's in a crate? Andrew Johnson
Prev: Re: Multiple IOC's in a crate? Andrew Johnson
Next: linux ioc console Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
