Hi Geoff,
> Is it possible to access an asyn driver started from epics from an
> external application? We need to serialize communication to a device
> and the hardware developers want to be able to use command line
routines
> for device access. Any suggestions on how to handle this situation
are
> appreciated.
I am not sure if I understand your question.
By "external application" do you mean a channel access client? By
"command line" do you mean the iocsh command line, or a channel access
command line client?
If you mean a channel access client then answer is yes for most drivers
and interfaces. The way to do it is with the asynRecord. In 3-3 the
asynRecord can control trace and connection management for any driver,
but it can only do I/O with asynOctet drivers. In the next release the
asynRecord can do I/O to all of the standard interfaces except
asynInt32Array and asynFloat64Array. It also supports "I/O Intr" record
scanning.
If you mean the iocsh command line then there are already commands
provided for doing I/O to asynOctet drivers. You can easily add
commands for doing I/O to other interfaces using the asyn*SyncIO
interfaces.
asyn3-3 external access Geoff Savage
Querying PCAS Michele Joyce
<2004>
<2004>
