I did run a test to see if I could successfully reboot an E5810.
Perhaps I did not have enough active gpib activity to cause the crashes
you are seeing.
Before the next release I will a harder test.
I do expect the errors you are seeing but It should recover and
reconnect when the E5810 is again alive.
that segmentation fault or Illegal Instruction should not happen.
Marty
john sinclair wrote:
Configuration:
linux x86, fedora core-2 with 2.6 kernel
EPICS 3.14.6
Async Driver 3-3
Device is E5810A ethernet - GPIB
The gpibCmd is
{&DSET_AI,GPIBREAD,IB_Q_LOW,"send","%lf",0,132,NULL,0,0,NULL,NULL,0}
Rebooting the E5810A while the ioc is running results in the following:
2004/11/03 17:08:17.480 L0 vxi11 clientCall errno 0 clnt_stat 5
L0 vxiWriteAddressed _? error : RPC: Timed out
2004/11/03 17:08:17.480 mirf:gig600Reading write status "L0 RPC failed
" requested 5 but sent 135129288 bytes
2004/11/03 17:08:17.480 mirf:gig600Reading error.
2004/11/03 17:08:17.480 mirf:gig600Reading lenmsg 5 but nchars written
135129288
2004/11/03 17:08:19.480 mirf:gig600Reading queueRequest failed timeWindow
active
2004/11/03 17:08:28.500 L0 vxi11 clientIoCall errno 0 clnt_stat 5
2004/11/03 17:08:28.991 L0 vxi11 clientCall errno 104 clnt_stat 4
2004/11/03 17:08:28.991 L0 vxiDestroyDevLink RPC error : RPC: Unable to send;
errno = Broken pipe
2004/11/03 17:08:28.991 L0 vxiDisconnectPort : RPC: Unable to send; errno =
Broken pipe
2004/11/03 17:08:31.000 L0 vxiDestroyDevLink RPC error : RPC: Unable to send;
errno = Broken pipe
Segmentation fault
Another failure gave these messages:
2004/11/03 17:16:02.500 L0 vxi11 clientCall errno 0 clnt_stat 5
2004/11/03 17:16:02.500 mirf:gig600Reading write status "L0 RPC failed
2004/11/03 17:16:02.500 mirf:gig600Reading error.
2004/11/03 17:16:02.500 mirf:gig600Reading lenmsg 5 but nchars written
135129288
2004/11/03 17:16:04.500 mirf:gig600Reading queueRequest failed timeWindow
active
2004/11/03 17:16:13.520 L0 vxi11 clientIoCall errno 0 clnt_stat 5
2004/11/03 17:16:15.871 L0 vxi11 clientCall errno 104 clnt_stat 4
2004/11/03 17:16:15.871 L0 vxiDestroyDevLink RPC error : RPC: Unable to send;
errno = Broken pipe
2004/11/03 17:16:15.871 L0 vxiDisconnectPort : RPC: Unable to send; errno =
Broken pipe
2004/11/03 17:16:17.880 L0 vxiDestroyDevLink RPC error : RPC: Unable to send;
errno = Broken pipe
Illegal instruction
For 10 reboots, the ioc reconnected 7 times and crashed 3 times
- async driver john sinclair
Reminder: EPICS meeting in ASIA, December 2004. registration Noboru Yamamoto
asynInt32SyncIO readOnce Geoff Savage
<2004>
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
