1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MVME 5500/6100: How to flash the VxWorks bootrom?
To: "Singleton, SJ (Steve)" <[email protected]>
Cc: "'Ralph Lange'" <[email protected]>, "'[email protected]'" <[email protected]>, [email protected]
Date: Mon, 01 Nov 2004 09:36:19 -0500
Hi all,
The instructions  for RTEMS-mvme5500  are simple :
MVME5500> gevEdit mot-script-boot
(Blank line terminates input.)
tftpGet -a4000000 -cxx.xx.xx.xx -sxx.xx.xx.xx -m255.255.254.0 -d/dev/enet0
-fepics/hostname/bin/rtems5500-cexp.bin
netShut
go -a4000000
Update Global Environment Area of NVRAM (Y/N) ? Y
MVME5500>
Note : (cxx.xx.xx.xx  means the client IP address and
        sxx.xx.xx.xx  means the server IP address)
The mvme5500 BSP is being added to the new RTEMS4.7 source tree,
which might take a while. Meanwhile, I posted the  entire
RTEMS-4.6.0 release with the MVME5500 BSP and patches applied at
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software
It can be downloaded  via :
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software/rtems-4.6.0_mv5500.tar.gz
Sorry if you think this is irrelevant.
Kate
"Singleton, SJ (Steve)" wrote:
> Hello Ralph
> Here are the instructions I wrote for people here at Diamond:
> 4.2     Loading the Boot ROM to Flash Memory
> This is necessary for new processor cards or to load a modified boot ROM.
> First power down and take out the processor, change jumper J8 (situated at
> the top back corner of the board) to boot from Flash 1 instead of Flash 0,
> insert the processor and power up again.   The following represents the
> necessary input/output on the debug port; user input is shown in bold;
> comment is in italics:
> Copyright Motorola Inc. 1999-2003, All Rights Reserved
> MOTLoad RTOS Version 2.0,  PAL Version 1.1 RM02
> Tue Jul 1 16:34:30 MST 2003
> MPU-Int Clock Speed =1000MHz
> MPU-Ext Clock Speed =133MHz
> MPU-Number/Type = 0/MPC7455
> MPU-Int Cache(L2) = 256K, Enabled, L2CR =0xC0000000
> MPU-Ext Cache(L3) =   2MB, Enabled, 200MHz, L3CR=0xDF826000
> Reset/Boot Vector    =Flash1
> Local Memory Found   =20000000 (&536870912)
> User Download Buffer =005C3000:007C2FFF
> MVME5500>  netShow
> Interface            EAddress               Status      Speed         Duplex
> /dev/enet0       0001AF0B1BEC     Down      Unknown  Unknown
> /dev/enet1       0001AF0B1BED     Up            100MBS     Full
> MVME5500> gevEdit mot-/dev/enet1-cipa       or /dev/enet0 if that is the
> active Ethernet port.
> 130.246.98.xxx          The IP address of the MVME5500
> Update Global Environment Area of NVRAM (Y/N)? Y
> MVME5500> gevEdit mot-/dev/enet1-sipa       or /dev/enet0 if that is the
> 130.246.98.xxx          The IP address of the machine from which the boot
> ROM is to be loaded.
> MVME5500> gevEdit mot-/dev/enet1-gipa       or /dev/enet0 if that is the
> 130.246.96.254          The IP address of the gateway
> MVME5500> gevEdit mot-/dev/enet1-file       or /dev/enet0 if that is the
> /tftpboot/mv5500.ROM           The name of the boot file
> MVME5500> tftpGet -d/dev/enet1 -r1 -v
> Network File Load in Progress...
> []><<<<<<<<<<<<<<<<<<< etc <<<<<<<<<<<<<<<<<<
> Bytes Received = &605920, Bytes Loaded =&605290
> Bytes/Second   = &605290, Elapsed Time =1 Second(s)
> MVME5500> flashProgram -o01f00100 -nfff00
> Source Starting/Ending Addresses         = 005C3000/006C2EFF
> Destination Starting/Ending Addresses = F3F00100/F3FFFFFF
> Number of Effective Bytes                         = 000FFF00 (&1048320)
> Program Flash Memory (Y/N)? Y
> Flash Memory Programming Complete
> The above seems to have worked for us; hope it helps with you.
> Regards
> Steve
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Ralph Lange
> Sent: 01 November 2004 13:17
> To: EPICS Tech-Talk
> Subject: MVME 5500/6100: How to flash the VxWorks bootrom?
> Hi all,
> with those new PPC board series Motorola seems to have switched from the
> good old PPCbug to something called MOTLoad.
> Does anyone have a clue or - even better - instructions on how to
> download and flash the VxWorks bootrom on one of these boards?
> Thanks a lot,
> Ralph
DST adjustment Peter Groszkowski
RE: MVME 5500/6100: How to flash the VxWorks bootrom? Singleton, SJ (Steve)
Prev: RE: MVME 5500/6100: How to flash the VxWorks bootrom? Singleton, SJ (Steve)
Next: DST adjustment Peter Groszkowski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
