1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: OSI connectWithTimeout
To: "'Peng, Sheng'" <[email protected]>, <[email protected]>
Date: Fri, 29 Oct 2004 17:22:06 -0600
I notice that connectWithTimeout *is* supplied in an RTEMS specific area of
base, but that this functionality isn't implemented in base for other OS. CA
handles this issue by letting connect() block in an independent thread while
detecting timeouts in another independent timer queue thread. The timer
queue thread interrupts the thread in the connect() call asynchronously when
a timeout is detected. The complication with this approach is related to
implementing the blocking socket call interrupt functionality uniformly
across the different OS. We *do* have an OSI interface for this in base
which isn't beauteous, but is functional on all OS so far encountered. Also,
with this design the connect() function is running in an independent thread
so timeout intervals are not critical. I notice that the RTEMS
implementation uses SO_RCVTIMEO. My experience has been that SO_RCVTIMEO is
fairly new and not uniformly implemented by the various socket libraries.
One could also use non-blocking IO and the select() function to implement
connectWithTimeout(). Starting with EPICS R3.14, my personal choice has been
to move away from non-blocking IO and select() based scheduling in favor of
thread scheduled implementations.
Jeff
> -----Original Message-----
> From: Peng, Sheng [mailto:[email protected]]
> Sent: Friday, October 29, 2004 4:06 PM
> To: [email protected]
> Subject: OSI connectWithTimeout
> Hi!
> Do we have an official OSI version of connectWithTimeout or I have to
> stay with my own?
> Thanks.
>                   Sheng
OSI connectWithTimeout Peng, Sheng
Prev: OSI connectWithTimeout Peng, Sheng
Next: MVME 5500/6100: How to flash the VxWorks bootrom? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
