1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Building RTEMS on Solaris
To: wtw00992 <[email protected]>
Cc: [email protected]
Date: Tue, 26 Oct 2004 16:39:01 -0500
wtw00992 wrote:
Greetings from L.I.
We currently run our Slow Controls for the STAR experiment at BNL using EPICS and VxWorks running on a Solaris.
We run solaris 8, gnumake 3.79.1, gcc 2.95.3, perl 5.005.
Last week we began our build of RTEMS and ran into several problems right from the start. We were trying to build for a target mvme167.
During the course of this we looked at many list serv archives, and I failed to see where anyone had had an issue with these target/platforms. I did see an email form Eric Norum regarding folks building for a mvme167 using RTEMS on a Linux... and it got me thinking that maybe no one is trying this. (Either that or its easy and we are just klutzes???)
Has any one tried building RTEMS for Solaris with this target? If so I would be interested in hearing from you.
For the record we tried the following:
We followed the tutorial http://www.aps.anl.gov/epics/base/RTEMS/tutorial/
The first trouble we had was with the "Get and build the development
tools". We simply couldnt get the RTEMS patches for gcc3.2.3 from the OAR site to work when we applied them on the solaris. We ignored this finally but clearly the RTEMS build failed with out the right tools. We eventually tried building the gcc tools on a Mac OSX and a Linux machine and they work ... so we took the patched files we created there and tried to compile those. Still when we tried to build RTEMS itself it stil failed. And despite some very powerfull wishful thinking our attempts to get EPICS to compile with this failed as well :-)
We also tried to ftp the latest version of the tools from the RTEMS site. Still the RTEMS build problems persisted.
I'm checking to confirm this, but I suspect that the problem will go away if you use GNU make rather than the SUN make. Just set the MAKE environment variable to gmake and try running the getAndBuild script again.
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-4793
Argonne National Laboratory
Building RTEMS on Solaris wtw00992
Prev: RE: gateway error message Jeff Hill
Next: [Fwd: JCA 2.1.4 and CAJ released!] Gasper Pajor
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Building RTEMS on Solaris wtw00992
Next: gateway error message Joan Sage
