Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Micro PLC <-> EPICS Communication ???
To: "Martin Pieck" <pieck@lanl.gov>
Cc: EPICS Tech-Talk <tech-talk@aps.anl.gov>
Date: Mon, 25 Oct 2004 10:40:44 +0200
Hi Martin,
If you can get an OPC server for your "sort of PLC" things you could run
the OPC Device Support (see EPICS Soft Support List for more info) and
connect to all such devices in one generic way.
Issues I can see:
 + All proprietary stuff is hidden in the commercially acquired OPC
   server, no need to dig into proprietary protocols and write specific
   Device Support
 + Different "sort of PLC" things can be accessed in a generic fashion
 + EPICS databases are configured straightforward and easy
 - Needs at least one dedicated Windows machine for the IOC / OPC client
   to run on
 - More layers = more places where things can break - which might be
   hard to track down
 - The OPC servers have to be configured to connect to the devices, so
   configuration effort is more or less shifted from EPICS to the OPC
   server layer
So you have to look at your existing hardware / software situation, OPC
server availability, and on who is going to implement and support this
stuff to decide if that's an interesting way for you to go.
Ralph
>>>>> "Martin" == Martin Pieck <pieck@lanl.gov> writes:
  > Does anyone every successfully communicated
  > via EPICS with a micro PLC like the type
  > found in the following link:
  > http://news.thomasnet.com/fullstory/450970
  > Has anyone any other suggestions or recommendation
  > of a "low budget" "sort of PLC" device that EPICS
  > can talk to ???
  > Thanks,
  > Martin
Micro PLC <-> EPICS Communication ??? Martin Pieck
Prev: RE: Micro PLC <-> EPICS Communication ??? Heron, M (Mark)
Next: MVME5110 and MPC7410 Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Micro PLC <-> EPICS Communication ??? Martin Pieck
Next: RE: Micro PLC <-> EPICS Communication ??? Heron, M (Mark)
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
