1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Micro PLC <-> EPICS Communication ???
To: "'Martin Pieck'" <[email protected]>
Cc: "Hamadyk, P (Paul)" <[email protected]>, [email protected]
Date: Mon, 25 Oct 2004 09:21:25 +0100
Hello Martin,
On Diamond we looked at number of low-end low-cost PLC solutions for
interlocking etc. Eventually we selected the Omron CJ1, which is a modular
solution, very compact and very cost effective. We interface this using the
RS232 communication interface on the processor module, for which Paul
Hamadyk wrote protocol support using the ORNL Serial framework.
This is one possible route, the alternative is to write you own comms
support  for the chosen device. We've found both ORNL Serial from John
Sinclair and Stream Device from Dirk Zimoch make writing comm. support
fairly straight forward.
Its worth noting that Marty Kraimer and others are working on a standardised
approach to asynchronous communication for  EPICS
http://www.aps.anl.gov/epics/modules/soft/asyn/index.html which is 3.14
based and is the future.
Regards.
> -----Original Message-----
> From: Martin Pieck [mailto:[email protected]]
> Sent: 22 October 2004 21:21
> To: [email protected]
> Subject: Micro PLC <-> EPICS Communication ???
> Does anyone every successfully communicated
> via EPICS with a micro PLC like the type
> found in the following link:
> http://news.thomasnet.com/fullstory/450970
> Has anyone any other suggestions or recommendation
> of a "low budget" "sort of PLC" device that EPICS
> can talk to ???
> Thanks,
> Martin
>                  (o -)
> --------------oOO-(_)-OOo-------------------------------------------
>  Martin Pieck              |     *           *               *   \\
>  MS H820, LANSCE-8,        | *        *        /\   *            =))
>  Los Alamos National Lab   |   * /\        *  /  \    /\  /\     //
>  Los Alamos, NM 87545, USA |/\  /  \/\      _/    \/\/  \/  \ *
>                            |  \/      \  /\/              o  \   *
>  (505) 665-0086 office     |           \/     __o       </\_  \   /\
>  (505) 665-5107 fax        |     /\o_         \<      __/\     \_/
>  (505) 661-7270 home       |  ^^^^^^^^^^   (()) (())    /
> ____________________________________________________________________
Prev: Re: list of *all* EPICS records Benjamin Franksen
Next: Re: Micro PLC <-> EPICS Communication ??? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Micro PLC <-> EPICS Communication ??? Ralph Lange
Next: MVME5110 and MPC7410 Dalesio, Leo
