Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: list of *all* EPICS records
To: mooney@aps.anl.gov
Cc: "'tech-talk@aps.anl.gov'" <tech-talk@aps.anl.gov>, <wrambold@gemini.edu>, <rambold@cfht.hawaii.edu>
Date: Mon, 18 Oct 2004 12:44:27 +0100 (BST)
Hi Tim,
There are several other custom records in use at Gemini:
deviceControl:   For control of the OMS-58 and the older OMS-8/44.
                 Understands Gemini's command/action protocol.
assemblyControl: For control of a collection of "devices" that
                 must work together to perform a specific instrument
                 function. Where device can be thought of as a single
                 moving component. Understands Gemini's
                 command/action protocol and has built in simulation
                 and debugging modes.
coordinateMotionControl:
                 Supports simultaneous moves along 3 axes
                 for DC servo motors and steppermotors
                 controlled by an OMS-58. Understands Gemini's
cmdTimeout:      Checks if a command reaches a subsystem and sets
                 an appropriate error string if a timeout occurs.
                 Based on Gemini's command/action protocol.
load:            Supports the uploading and downloading of
                 command strings through the PMAC mailbox registers.
lutin:           Lookup table input record. Converts 4 input values
                 into a character string.
lutout:          Lookup table output record. Converts a character string
                 tag into 4 output values.
status:          Like an "mbbiDirect" but for 32-bits.
Cheers,
Andy
Observatory Sciences Limited    Email: ajf@observatorysciences.co.uk
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
RE: list of *all* EPICS records Kevin Tsubota
Prev: Re: linking iocCore lib error Till Straumann
Next: Re: list of *all* EPICS records -- summary (long) Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: RE: list of *all* EPICS records Kevin Tsubota
Next: Re: list of *all* EPICS records Siddons, David
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
