so I'm looking at fixing that. We already have the IVOA and IVOV fields that can be used to tell the record what to do when it has an undefined value, and I intend to make use of this mechanism to control what happens when a NaN value is discovered. For those interested, my solution is basically that instead of setting prec->udf to FALSE, it should be set to isnan(prec->val). The line where udf actually gets set may have to move around a little in some cases, but the idea is basically to ensure that anytime VAL is NaN that UDF gets set, so the record will go into a UDF/INVALID alarm state. I'll be applying this fix to the other standard record types that have a VAL field of type DBF_DOUBLE. It doesn't make sense for the array record types though, and the digital and long types don't need to worry about NaN values anyway. As far as the handling of NaNs elsewhere, Eric provided some information about how the different platforms C libraries cope - on Unix it is already possible to use "NaN" in your .db files (and probably in .dbd files too). There will be some more checking and additional work needed for handling NaNs in the numeric type conversions though. I personally think NaN should be made as full a citizen as it reasonably can be, so I would definitely vote against changing the behaviour of CA, following the principle of least surprise - apparently it works at the moment, so don't break it! Eric is working on an epicsStrtod() routine to make string input conversions work everywhere, but we can't expect to be able to fix everything until the platform's C libraries cooperate. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
