there is a bug in "probe". Here I have version 1.1.2 (8-2-2002). Can anyone fix it? The problem appears in the following constellation: Probe displays a record field of type ENUM (i.e. the VAL-field of mbbi). The value of the field has no corresponding string defined. The modify-window of probe is open. If the record field is invoked and the modify-window is open or is opened afterwards no problem appears. If the modify-window remains open and the value of the field changes from a defined (with corresponding string) to an undefined (without corresponding string) probe will crash. Bernd
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
