Hi, 1. I would like to write portable server. There is tutorial of portable server. It has example. But example has mistakes and it is like Epics base h file were changed too. I spent some time to build it but hasn't success. Has anybody working code of portable server from tutorial or code of the simplest another portable server? I have 3.14.4, Windows XP, MVC++ 6.0. There is an portable server template provided for use with makeBaseApp.pl in your version of Base, which should give you a working example. To create an application to try out, run makeBaseApp and specify caServerApp as the template type - something like this, but you'll probably have to modify the command somewhat to get it to run on Windows (which I can't help you with as I only use Unix): mkdir example cd example perl /path/to/base/bin/win32-x86/makeBaseApp.pl -t caServerApp server This will create the necessary files to make your own server, which you can then compile, edit and experiment with. Be sure to read the README text file in the serverApp subdirectory for more information about the server. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
