Hi again- now that I know it's the "-mstrict-align" that's causing the byte operations, I still have 2 questions... You should be able to just include a new definition of ARCH_DEP_CFLAGS in your Makefile, inside an architecture test comparing $(T_A) against your specific target arch. 2) What switch (or lack of) does this compiler need to turn this feature off? A quick naive test of re-running just the gmake-generated ccpcc command without the mstrict switch makes the assembly phase barf, though I'm easily convinced that this may be due to the lack of proper environment caused by running it in isolation: Correct, the R3.14 build system sets up some environment variables that tell the compiler where to find its components. You should read this tech-talks message first though, which describes why we added that -mstrict-align flag in the first place: http://www.aps.anl.gov/epics/tech-talk/2000/msg00529.php You can discover whether your compiler includes the fix for that original problem by running <tornado>/host/<arch>/bin/ccppc -v If you find the number 28373 in the output from that command you *may* be ok to omit the -mstrict-align in that our original bug *probably* wont recur. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
