1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: JCA 2.1.3 released
To: Till Straumann <[email protected]>
Cc: [email protected]
Date: Tue, 07 Sep 2004 15:31:14 +0200
Yes, you are right, this means "You're wrong." :)
JCA is a set of interfaces allowing to "plug" CA implementation and until recently only JNI implementation exitsts.
We developed a pure java implementation of a CA client called CAJ (Channel Access in Java), which will "plug" into the JCA - this means all the applications will require only 1 line of change (due to current design) to make it work with CAJ. Also CAJ can (and probably will) be included in the next JCA release (2.2).
We expect to release CAJ soon. We want to do some more thorough testing before doing so :)
Till Straumann wrote:
I've not been following JCA development closely, sorry, but I thought
JCA was a 'true' java implementation of a CA client. However, from peeking
at the on-line document I got the impression that I'd still
need a native CA client library (what is JNI?). Please tell me I'm wrong.
Thanks
-- Till
JCA 2.1.3 released Rok Sabjan
Re: JCA 2.1.3 released Till Straumann
Prev: Re: JCA 2.1.3 released Till Straumann
Next: Re: Converting GPIB device support from R3.13.9 to R3.14.6 Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Record Type Doc Benjamin Franksen
