1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: building base3.14.5
To: Zhao Zhuo <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 3 Sep 2004 10:29:26 +0200
  >> Zhao Zhuo wrote:
  >> I'm building base3.14.5 for vxworks-ppc604 on solaris 8 SUN Workstation with gcc.
  >> However it showed the following error,why?
>>>>> Andrew Johnson <[email protected]> writes:
  > Your errors are actually from building one of the host tools for your
  > solaris-sparc-gnu target, and probably mean that you're going to have to
  > upgrade the gcc and g++ version on the Solaris workstation.  This is
  > nothing to do with vxWorks at all, it's related to the compiler that
  > builds code to run on Solaris.  The upgrade will not cost any money, but
  > will have to be done by your Solaris systems administrator.
  > What is the version of your current g++ on your workstation?  Run this
  > command and send us the output:
  >   /usr/local/bin/g++ --version
  > I don't know what the earliest version of gcc that will work is, at APS
  > we're now using gcc 3.2 or later on all our systems.
Even though it may not be related to your gcc problem on Solaris:
The latest released version of EPICS base is 3.14.6 - if you do not have
a particular important reason to build a specific version, you should
try to avoid starting something with old versions of things.
I would suggest switching to the latest release (available from the
EPICS web site at APS). It may not solve your gcc problems, but you
probably avoid other issues in 3.14.5 that have been fixed.
Ralph
Re: building base3.14.5 Zhao Zhuo
Re: building base3.14.5 Andrew Johnson
Prev: Re: LabVIEW/EPICS Brand Dr. Holger
Next: Re: building base3.14.5 Zhao Zhuo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: building base3.14.5 Andrew Johnson
