As far as I know, that is a characteristic of the SPARC processor,
and cannot be
influenced by compiler directives. You *can* use byte-oriented
instructions on
data which is not on "natural" boundaries. I.e. you could access "lInt"
as follows
(from a packed array):
unsigned long int temp;
memcpy(&temp, &testdata.lInt, sizeof(temp));
printf("testdata.lInt = %lu", temp)
HTH -- Larry
does not print the right value. A pointer to an unaligned structure member results in a segment violation.
- Re: Compiler switches on RISC byte alignment Kay-Uwe Kasemir
- RE: Compiler switches on RISC byte alignment Fairley, Diane
<2004>
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
