1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: building base3.14.5
To: Zhao Zhuo <[email protected]>
Date: Thu, 02 Sep 2004 11:40:35 -0500
Zhao Zhuo wrote:
> I'm building base3.14.5 for vxworks-ppc604 on solaris 8 SUN Workstation with gcc.
> However it showed the following error,why?
> /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so: undefined reference to `cerr'
> /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so: undefined reference to `logic_error virtual table'
> /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so: undefined reference to `endl(ostream &)'
> /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so: undefined reference to `__out_of_range(char const *)'
> /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so: undefined reference to `ostream::operator<<(char const *)'
> /export/home/zhaozhuo/gateway/base-3.14.5/lib/solaris-sparc-gnu//libCom.so: undefined reference to `__length_error(char const *)'
Your errors are actually from building one of the host tools for your
solaris-sparc-gnu target, and probably mean that you're going to have to
upgrade the gcc and g++ version on the Solaris workstation.  This is
nothing to do with vxWorks at all, it's related to the compiler that
builds code to run on Solaris.  The upgrade will not cost any money, but
will have to be done by your Solaris systems administrator.
What is the version of your current g++ on your workstation?  Run this
command and send us the output:
  /usr/local/bin/g++ --version
I don't know what the earliest version of gcc that will work is, at APS
we're now using gcc 3.2 or later on all our systems.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
Re: building base3.14.5 Ralph Lange
building base3.14.5 Zhao Zhuo
Prev: building base3.14.5 Zhao Zhuo
Next: RE: Compiler switches on RISC byte alignment Fairley, Diane
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: building base3.14.5 Ralph Lange
