1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: How to pass constant string into a genSub or sub record
To: EPICS tech-talk <[email protected]>
Date: Thu, 05 Aug 2004 03:06:00 -0700
Hi folks,
This concerns subroutine and genSub records in EPICS R3.13.4.
I need to pass a string into a subroutine or general subroutine
record at initialization time because I don't want to fix the information
in the code for the record's init and process routines.
So I assigned the string to an input link in the .db file, just as one
would pass a numeric constant.  However, the record interprets the string
as a PV name, which generates a lot of pointless network traffic as link
processing looks for a record with that name.
Is there a way to tell the record that the string is a constant and
not a PV name?  Do I have to use a string record to hold the string
and use the input link as a link?  Or is there another, better way to
do it?
	Thanks in advance,
	Susanna
Susanna Jacobson                MS 10-110
[email protected]              Lawrence Berkeley National Laboratory
VOICE:  (510) 486-7801          1 Cyclotron Road
FAX:    (510) 486-7374          Berkeley, CA 94720
Re: How to pass constant string into a genSub or sub record Peregrine McGehee
Prev: RE: Program calling CA from witrin a posix signal handler Jeff Hill
Next: Re: How to pass constant string into a genSub or sub record Peregrine McGehee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: problem with the monitor-function (c++) Jeff Hill
