John,
I have had a problem in the past with CA clients
disconnecting ~ 2 hr, but this only happened if all of the
PV values being monitored by the client application did not
change during that time. I repeatedly measured this
'inactivity' disconnect time to be 2 hours, 11 minutes, and
15 seconds.
No one could explain the true cause, I just added a PV that
changed fairly often to the list of monitors.
-ps
----- Original Message -----
To: <[email protected]>
Cc: <[email protected]>
Sent: Friday, July 30, 2004 1:32 PM
Subject: RE: problem with the monitor-function (c++)
Hello John,
> The program already works, but after a time (~ 2 h) the
> monitor-functions just disconnect and the program abort.
One possible cause of trouble in a single threaded program
would be not
calling ca_pend_event() periodically although this theory
does not fit well
with the 2 hr delay before the disconnect.
To get a better understanding of your issue some additional
details will be
helpful:
o What version of EPICS are you running?
o What operating system are you using when this occurs?
o You mention that "monitor-functions just disconnect". Did
monitor updates
cease to occur, did the channel receive a disconnect
callback, or did the
software terminate in some way?
o You mention that that the program aborts. Was there a
failure? For example
a bus error, or did the program abort because of a fatal
severity channel
access exception? If so, then please copy the output from
the exception
message into an email reply. If the program died in some
other way then
please elaborate on the circumstances.
o When this problem is occurring do you get a successful
response from "ping
<IOC name>" executed on the same host as yor CA client?
o You might also try "telnet <IOC name>" as that will
confirm TCP
connectivity from the same host as the CA client.
o Finally, when the program is in this disconnected state,
does rebooting
the IOC cause the monitor updates to start up again (this is
assuming that
the software didn't abort)?
> I had looked into iocinf.c and i think there is a counter,
who
> disconnect the monitor-function. Why?
The CA client library monitors connectivity with the servers
and notifies
the application program when connectivity has been lost. The
library watches
for beacons from the server. If a beacon does not show up
for
EPICS_CA_CONN_TMO seconds then the library sends an
are-you-there message to
the IOC. If there isn't a prompt response then the
application receives
disconnect notification. The details on all of this are in
the CA reference
manual.
Sorry to answer your question with questions of my own, but
I will need more
details in order to determine what is occurring there and if
it is a bug.
Sorry about the delay responding.
Jeff
> -----Original Message-----
> From: [email protected]
[mailto:[email protected]]
> Sent: Thursday, July 29, 2004 2:34 AM
> To: tech-talk
> Subject: problem with the monitor-function (c++)
> Hi all members,
> my name is John Kettler and i am a beginner.
> I use the Channel Access (epics) to communicate with a VME
Crate. For
> this i put monitor-functions with ca_search_and_connect,
ca_pend_io,
> ca_add_event and ca_pend_event. The program already works,
but after a
> time (~ 2 h) the monitor-functions just disconnect and the
program
> abort. I can restart the program without any problem.
> When i reboot the Crate the program works on, so i can say
it's no
> problem with the network connection.
> The message i get is the following:
> CA.Client.Diagnostic.....................................
> Message: "Network conncetion lost"
> Serverity: "Warning" Context: "test1:5064"
> Source File: ../iocinf.c Line Number:1504
who
> So, if you have an answer please let me know.
> John
> John Kettler [email protected]
> DELTA - Univesität Dortmund
http://www.delta.uni-dortmund.de
- RE: problem with the monitor-function (c++) Jeff Hill
<2004>
<2004>
