1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Re: RTEMSfor MVME5500
To: "KateFeng" <[email protected]>, "KimanHa" <[email protected]>
Cc: [email protected], [email protected]
Date: Mon, 26 Jul 2004 23:32:39 +0900
Hello Kate,
>RTEMS-4.6.0 is better than  RTEMS-4.6.0pre#.   RTEMS-4.6.0 has
>PowerPC patches  for RTEMS-4.6.0pre#.
He tried to recompile RTEMS-4.6.0 kernels and GeSys_2.1beta codes.
All passed before step what for build cexp : and xsyms :
>To build rtems5500-cexp.bin and rtems5500-cexp.sym :
>0) cd RTEMS5500-GeSys_2.1.beta
>1) make
Did you used bspcheck commands at Makefile line 142.
But when i type make commands after other error messages from Makefile line 142..
What is missing ?
root@rtemsdev RTEMS5500-GeSys_2.1.beta]# make
Makefile:142: *** GeSys has not been ported/tested on this BSP (mvme5500) yet.
Makefile: 142 Line :
all: bspcheck libnms ${ARCH} $(SRCS) $(PGMS)
Kiman,
PLS control and taskforce team.
> -----Original message-----
> From: "KateFeng"
> To: "KimanHa"
> Cc: [email protected],[email protected]
> Date: 07/17/2004(Sat)01:32
> Subject: Re: RTEMSfor MVME5500
> Kiman Ha wrote:
> >  Hello Kate,
> > Anyone have to tried compile RTEMS for MVME5500?
> > Our Control staffs who Mr OH is recently trying to compile RTEM for
> > MVME5500.
> > But he reported to me some compile error messages
> > Used : RTEMS-4.6.0pre1
> PowerPC patches  for RTEMS-4.6.0pre#.  However, the patches
> does not seem to be related to the building error you got.
> > But the compile error is occurs this step;
> > 2) make
> >  ldep/ldep.c:659:2: warning: #warning TODO weak symbols
> > Warning: Symbol without object file??
> > -> substituting symbol file name, using 'startfiles.o'...
> > (o-optimize/startfiles.nm/line 1)
> > Warning: type mismatch between multiply defined symbols
> >          __deregister_frame_info: known as T, is now w
> >          __register_frame_info: known as T, is now w
> >          environ: known as G, is now B
> > Warning: Object
> > '/work/rtems/rtems-ppc/lib/gcc-lib/ppc-rtems/3.2.1/../../../../ppc-rtems/lib
> > /libbfd.a[archive.o]' couldn't be removed; probably it's needed by the
> > application
> > Warning: Object
> > /libbfd.a[archures.o]' couldn't be removed; probably it's needed by the
> > application
> > Warning: Object
> > /libbfd.a[bfd.o]'
> > Warning: Object
> > /libiberty.a[xexit.o]' couldn't be removed; probably it's needed by the
> > application
> > Warning: Object
> > /libiberty.a[xmalloc.o]' couldn't be removed; probably it's needed by the
> > application
> > Warning: Object
> > /libiberty.a[xstrerror.o]' couldn't be removed; probably it's needed by the
> > application
> > Warning: Object 'librtemscpu.a[dummy.o]' couldn't be removed; probably it's
> > needed by the application
> > Warning: Object
> > application
> I got all these warning message as well except the directory is
> '/work/rtems/ppc-rtems//lib/libxxx.a'  instead.  Where  was  your  cexp
> library copied to ?    Theoretically, 'make install' should do the job.
> However, sometimes one might have to manually install some or all of
> the libraries to  /opt/rtems/ppc-rtems/lib and the header files to
> /opt/rtems/include, which is mentioned at the end of INSTALL.
> > Object
> > /librtemsbsp.a[ftpd.o]' not found!
> As well, I got  :
> Warning: Object '/opt/rtems3/ppc-rtems//lib/libiberty.a[strncmp.o]'
> couldn't be removed; probably it's needed by the application
> Object 'librtemsbsp.a[ftpd.o]' not found!
> However, the 'make' continued as what  is attched (GeSys.log)
> Is  librtemsbsp.a installed ?   He might have missed
> one step in installing the  BSP libraries.  Thesy should be in
> /opt/rtems/ppc-rtems/mvme5500/lib directory.  The
> mvme5500Lib.tar.gz should be tared  into /opt/rtems/ppc-rtem.
> I updated the README to cover some more details (attached).
> > --- end of error message ---
> > When are you going to release the BSP source code for MVME5500?
> We followed the advice of the legal office to submitt  a  letter for approval
> of releasing the source code, which hopefully  will  be approved soon.  It is
> a standard procedure that we never  did  before.  Thanks for your patience.
> Some VME modules (e.g. Oms58 driver) might require  PCI sync
> command if mvme5500 is used as the SBC.  Please reference the drvOMS58.cc
> file that is posted in synAppRTEMS.  Even so,  I appreciated the runtime
> performance of RTEMS-mvme5500.   It's faster in initilaizing the same amount
> of motors as compared with mv2307.  The  MEDM screen  for the mv5500 IOC
> startups so much faster than  that of the mv2307  when I needed it for
> 32 motors.
> Regards,
> Kate
Re: RTEMSfor MVME5500 Kate Feng
Prev: Re: Motorola 5100 Ralph Lange
Next: Re: RTEMSfor MVME5500 Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Motorola 5100 jihkim
