1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CA Gateway
To: TECHTALK <[email protected]>
Date: Mon, 19 Jul 2004 16:30:56 +0200
Hi all,
I'm using gateway2_0_0_0Beta8 (with R3.14.6) and have some strange problems:
1. The archiver gets a lot more data. Is ADEL ignored through the gateway? Does the gateway make DBE_VALUE monitors from DBE_LOG monitors?
I tried '-mask avl' but that didn't help.
If the gateway does not preserve the type of monitor (v or l), why not?
2. The alarm handler cannot reset alarms in global mode. The documentation says it can. Do I need some special command line option?
3. When I write to a motor record through the gateway, the complete medm display sometimes hangs until the motor has stopped. Gateway 1.3 did even crash here sometimes.
Any idea what's wrong?
Dirk
-- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
Re: CA Gateway Ralph Lange
Prev: [no subject] bwaggoner
Next: Re: CA Gateway Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
