Hello,
I see my name here.
My goal was a little another. I checked performance of record
processing in my problem. It is like that record processing is slow.
Thanks, Andrei.
-----Original Message-----
Sent: Tuesday, July 06, 2004 8:42 AM
To: '[email protected]'
Subject: Re: initializing a waveform record
Hello Mark, Steve
We came across the same problem - filling the waveform with static data
- and the best solution we found so far is the use of state notation
language.
Here is an example code for what we do :
double arr[100];
assign arr to "CURVES:SINE";
%% int i;
state init
when()
%% for(i=0;i<100;i++) arr[i] = sin(0.1*i);
%% j=0;
pvPut(arr);
} state somethingelse
We use sequencer and 2.0.8 and epics base 3.14.x.
Hope this helps,
Gasper Pajor,
Cosylab
Singleton, SJ (Steve) wrote:
> Hello Mark
> I use EPICS subroutine (SUB) records to initialise waveform records,
with
> the attached code. Because of the limitation on the number of
> arguments to
> a SUB record it is only possible to initialise up to nine elements of
the
> array from one SUB record. The arguments of the SUB record are as
> follows:
> INPA - the waveform record
> INPB - the index number of the first waveform element to be set up by
> this
> SUB record.
> INPC - the number of elements to be initialised by the SUB record, in
the
> range 1 - 9.
> INPD to INPL - the values to which the elements are to be set.
> Hope this helps.
> Regards
> Steve Singleton
> From: [email protected]
> [mailto:[email protected]]On Behalf Of Mark M. Ito
> Sent: 04 July 2004 02:14
> To: [email protected]
> Subject: initializing a waveform record
> What is there a standard way to initialize the values of a waveform
> record?
> I saw Andrei Liyu's post from this past Apr. 8. He seems to imply that
> the standard is to call dbPutField. Does one write a VxWorks
> subroutine to make this call and load the array?
> The array is of floats, and will be about 100 elements long. The
> values are static; they never change.
> I also looked at the waveform record description in the Record
> Reference Manual. That did not help me given my lack of basic
> understanding of this stuff.
> I also skimmed the contents of the Application Developer's Guide. No
> help for me there either.
Re: initializing a waveform record Ned Arnold
Re: initializing a waveform record Tim Mooney
<2004>
Array save/restore Tim Mooney
EDM Help File problems Steven . Banks
<2004>
