1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS naming services
To: "'[email protected]'" <[email protected]>
Date: Sat, 03 Jul 2004 19:12:44 +0200
Andrew Johnson wrote:
Luedeke Andreas wrote:
at the SLS we upload the channels at boot time from the IOC to an oracle table. This is done by a perl script running on the boot pc started by the ioc using rsh, reading a file generated before by the IOC using the dbl command. Not quite the portability you would like to have for epics 3.14 applications: you need to save a file from the IOC and you need to have an rsh mechanism.
The rsh mechanism is not essential if you arrange to have a program running on the fileserver which is monitoring all of the dbl output files; when it notices a change it triggers the update sequence. If you're not so worried about short delays you could also just have a cron job that periodically checks for updates. This might also be more appropriate if the processing after a reboot can take a long time to run, as you can limit how often the processing can be started.
Bear in mind that the list of PVs (i.e. CA Channel names) is not the same as the output from dbl, which just gives you the record names. A truly omniscient nameserver would also need to know the record type, and the set of publicly accessible field names for that record type on that particular IOC [don't forget that two IOCs that use two different DBD files can have a different set of fields in the same record type, you must make sure you're using the IOC's DBD file to be sure what fields it will have]. A simple way to resolve this would be to dump the DBD file at boot time as well as the dbl output.
It should be relatively straightforward to write some IOC-side code which queries the database in memory using dbStaticLib routines, and sends the results directly to the name server; I'm not aware of anyone who has actually implemented something like this though. This code would be able to resolve the field names issue without having to write a parser to extract the DBD filename(s) from the st.cmd file.
I would be still interested to hear more about the straightforward way Andrew mentions here.
Sending:
- the record name
- the record type
- the DBD files - but only if requested (as an option)
DBD files are not necessary if the database loaded has been created from Oracle which generates databases with a certain set (version) of DBD files. In other cases the DBD files might have a version number. The little task on the IOC would only have to send the version number (defined on the IOC as an env. variable) along with the record names/type information.
Combining this little task on the IOC with the ca name server from Joan Sage would add functionality to it. Connecting the ca name server to Oracle(option) and adding an LDAP server(option) would complete the picture many of us might have in mind.
-Matthias
[Fwd: Re: EPICS naming services] Luedeke Andreas
Re: EPICS naming services Andrew Johnson
Prev: RE: EPICS naming services Allison, Stephanie
Next: initializing a waveform record Mark M. Ito
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS naming services Luedeke Andreas
