Hello, Hi, at the SLS we upload the channels at boot time from the IOC to an oracle table. This is done by a perl script running on the boot pc started by the ioc using rsh, reading a file generated before by the IOC using the dbl command. Not quite the portability you would like to have for epics 3.14 applications: you need to save a file from the IOC and you need to have an rsh mechanism. Anyway, if you're interested, have a look at: http://www.lnf.infn.it/conference/pcapac2002/TALK/WE-06/WE-06_talk.pdf http://www.lnf.infn.it/conference/pcapac2002/TALK/WE-06/WE-06.pdf http://www.diamond.ac.uk/Activities/EPICS/Thursday_PM/ChannelManagement2002.ppt I can send you a zip with all the scripts and some documentation, if you think it is worth looking into it. If not, are there any thoughts regarding standard directory services interfaces (COS naming, LDAP) etc. that would be acceptable to the community. I realise that this has been an issue for some time. If you want to make a proposal I would really like to read it :-) Kind Regards Andreas -- Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002 mailto:[email protected], http://people.web.psi.ch/luedeke
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
