1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: XML-RPC library for PHP
To: Noboru Yamamoto <[email protected]>
Cc: [email protected], Bertrand Alain <[email protected]>
Date: Tue, 29 Jun 2004 15:28:19 +0200
Hi Noboru,
we developed in SLS a php module which allows to talk to an EPICS channel from a php page. You just need to load this module in your php code and call ca functions (caget, caput or camonitor). The usage is very simle and performace very good.
You can download the module and get the documentation on:
http://www.sls.psi.ch/controls/help/howto/php_epics.html
Hope this helps. Best regards,
Renata and Alian
Noboru Yamamoto wrote:
We are now developing a Web application which display a graph of Channel
Archiver
XML-RPC data server. It try to imitate CGIExport in the older version of
Channel Archiver.
Mr. Susumu Yoshida wrote a program using Apache+PHP+gnuplot and we
started the
evaluation of program. Soon, we noticed that XML-RPC library we used in
PHP is not
as fast as that in Perl or Python.2.3.x.
After studying the Web for a while, we found that there are several
version of XML-RPC library
for PHP.
Does anyone know which version of these libraries is the fastest and
reliable
Your comments and suggestions will be greatly appreciated.
Thank you for your cooperation.
Noboru Yamamoto
KEKB control group
KEK, JAPAN
[email protected]
_/_/_/ _/ _/_/_/ Computing & Controls
_/ _/ _/ Paul Scherrer Institute _/_/ _/ _/_/ CH-5232 Villigen-PSI
_/_/ _/ Tel: ++41 56 310 5124
_/_/_/_/_/_/_/__/_/_/ http://people.web.psi.ch/krempaska/index.html
Re: XML-RPC library for PHP Noboru Yamamoto
Prev: XML-RPC library for PHP Noboru Yamamoto
Next: Re: XML-RPC library for PHP Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
