Hello Lifang,
I concur with what Ralph has already said and would like to add some further
comments.
> > CA.Client.Exception..........................
> > Warning: "Virtual circuit disconnect"
> > Context: "192.168.26.11:5064"
> > Source File: ../cac.cpp line 1147
> > Current Time: Mon Jun 28 2004 16:37:11.282870000
Of course, this type of message is normal if EDM looses network connectivity
with the IOC. Otherwise, what version of EPICS are you using? I seem to
recall that there were some problems with erroneous CA client library
disconnects in the very earliest beta releases of EPICS R3.14.
Jeff
> -----Original Message-----
> From: Ralph Lange [mailto:[email protected]]
> Sent: Monday, June 28, 2004 6:52 AM
> To: Zheng Lifang
> Cc: EPICS Tech-Talk
> Subject: Re: virtual circuit disconnect
> Hi Lifang,
> you shouldn't have to set the EPICS_CA_ADDR_LIST in that case, as using
> a broadcast on the local network is the default behaviour when a CA
> clients wants to connect.
> Do you get the same results if you don't set the variable - neither on
> the PC nor on the IOC?
> Regards,
> Ralph
> >>>>> "Zheng" == Zheng Lifang <[email protected]> writes:
> > Hi All,
> > We set 192.168.26.n as our control subnet. A PC/Redhat9.0 (with its
> IP 192.168.26.2) runs edm, and its netmask is set to ffffff00 . The IOC
> IP address is set to 192.168.26.11:ffffff00 in the boot parameter.
> > The IOC downloads vxWorks and EPICS normally from PC/Redhat. In
> st.cmd there is putenv("EPICS_CA_ADDR_LIST=192.168.26.255") before
> iocInit. Also in PC/Linux I set EPICS_CA_ADDR_LIST=192.168.26.255
> in .bash_profile .
> > But sometime edm can't connect to IOC, and displays the following
> messages:
> > Where do I set incorrectly or should pay attention more?
> > Regards,
> > Lifang
- Re: virtual circuit disconnect Ralph Lange
caRepeater working practices Simon Rees
<2004>
<2004>
