please let me ask a question of a beginner. I tryed the example applications of baseR3.14.6 on SUSE linux 9.0. Everythink works well. Now I tryed to change the name of the Sequencer program to find out, how I can install my own program. For this I did the following: coppy "sncExample.stt" to "sncProgram2.stt" and change the first line to: program sncProgram2 changed the "Makefile" in exampleApp/src/ to: ifneq ($(SNCSEQ),) # This builds sncExample as a component of example # example_DBD += sncExample.dbd # example_SRCS += sncExample.stt # example_LIBS += seq pv # The following builds sncProgram as a standalone application PROD_HOST += sncProgram2 sncProgram_SNCFLAGS += +m sncProgram_SRCS += sncProgram2.stt sncProgram_LIBS += seq pv sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS) endif changed the last line of "st.cmd" to: seq sncProgram2,"user=wehlerHost" running "make" I get the following error message: /home/wehler/EPICS3/SEQ/seq-2.0.8/bin/linux-x86/snc .../sncProgram2.stt -o sncProgram2.c /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/wehler/EPICS3/SEQ/seq-2.0.8/include/os/Linux -I/home/wehler/EPICS3/SEQ/seq-2.0.8/include -I/home/wehler/EPICS3/base-3.14.6/include/os/Linux -I/home/wehler/EPICS3/base-3.14.6/include sncProgram2.c /usr/bin/g++ -o sncProgram2 -Wl,-rpath,/home/wehler/EPICS3/TOP_SEQ3a/lib/linux-x86 -Wl,-rpath,/home/wehler/EPICS3/SEQ/seq-2.0.8/lib/linux-x86 -Wl,-rpath,/home/wehler/EPICS3/base-3.14.6/lib/linux-x86 sncProgram2.o /usr/lib/gcc-lib/i586-suse-linux/3.3.1/../../../crt1.o(.text+0x18): In function `_start': .../sysdeps/i386/elf/start.S:98: undefined reference to `main' sncProgram2.o(.text+0x6): In function `sncProgram2Registrar': : undefined reference to `seqRegisterSequencerCommands' sncProgram2.o(.text+0x13): In function `sncProgram2Registrar': : undefined reference to `seqRegisterSequencerProgram' sncProgram2.o(.text+0x46): In function `D_ss1_low': : undefined reference to `seq_delayInit' sncProgram2.o(.text+0x99): In function `E_ss1_low': : undefined reference to `seq_delay' sncProgram2.o(.text+0xf6): In function `D_ss1_high': : undefined reference to `seq_delayInit' sncProgram2.o(.text+0x149): In function `E_ss1_high': : undefined reference to `seq_delay' collect2: ld returned 1 exit status make[3]: *** [sncProgram2] error 1 make[3]: Leaving directory `/home/wehler/EPICS3/TOP_SEQ3a/exampleApp/src/O.linux-x86' make[2]: *** [install.linux-x86] error 2 make[2]: Leaving directory `/home/wehler/EPICS3/TOP_SEQ3a/exampleApp/src' make[1]: *** [src.install] error 2 make[1]: Leaving directory `/home/wehler/EPICS3/TOP_SEQ3a/exampleApp' make: *** [exampleApp.install] error 2 The same message arises when I build the directory structure with ..../makeBaseApp.pl -t caClient caClient Can someone explain me what I did wrong? Thanks in advance Dorothea Wehler ------ Dr. Dorothea Wehler Cryoelectra GmbH Linde 72-74 D-42287 Wuppertal, Germany Tel: +49 202 / 69824-17 Fax: +49 202 / 69824-40
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
