1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PREC
To: Eric Norum <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Fri, 11 Jun 2004 18:10:47 +0200
But what does this exactly mean? I think, the most intuitive sense is to format the value like "%.<PREC>f". At least this is the default behaviour of medm when using a text monitor. But why not like "%.<PREC>g" or "%.<PREC>e"? And why does neither caget nor camonitor honor PREC? And what about negative PREC values?
I'm not sure that the most intuitive sense is "%.<PREC>f". I interpret the documentation to mean that PREC should result in "%.<PREC>g".
That's my problem: It is not documented what PREC really means. Of course, one can look into the code as Marty suggested, but not many people can really find out what's going on in EPICS just by looking in the code :-) Even after finding and understanding cvtFloatToString, etc. it is hard to say under what circumstances those functions are used.
To ignore PREC > 8 and use "%12.5e" instead is not what I expected (found in cvtFloatToString). Even though it seems reasonable, because the precision of a float is very limited.
I found that in cvtFloatToString, etc., the precision argument is unsigned short. This does not match the definitions of the PREC fields in the dbd files.
I suggest the following: PREC >= 0 means to format the value like printf("%.*f",PREC,VAL); PREC < 0 means to format the value like printf("%.*e",-PREC,VAL);
I worry that there are a lot of tools out there that might not take well to negative PREC values.
All tools including caget and camonitor should honor PREC.
Any comments?
I'd argue that PREC should specify the number of significant digits and that the style (f/e) should be chosen according to the printf rules:
If the precision is missing, 6 digits are given; if the
precision is zero, it is treated as 1. Style e is used if the
exponent from its conversion is less than -4 or greater than or
equal to the precision. Trailing zeros are removed from the
fractional part of the result; a decimal point appears only if it
is followed by at least one digit.
With PREC=2, pi would print as 3.1, pi/100 as 0.031, pi/10000 as 0.00031, pi/100000 as 3.1e-5, pi*10 as 31 and pi*100 as 3.1e2.
printf "%g" works this way, but EPICS obviously not:
record (ai, "ai") {
    field (PREC, "2")
    field (VAL, "3.1415")
record (stringin, "string") {
    field (INP, "DZ-AI")
    field (PINI, "YES")
The value of string is "3.14"
When I use 'field (PREC, "-2")', the value of string is "3.14150000000000018e+00"
All in all, it was just an idea, how one could define in the record how the value should be shown and not in caget or the adl file. It is more in line with the EPICS philosophy (as I understand it) to configure as much as possible on the record level. A change in cvtFloatToString, etc. could possibly do it for most applications.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
PREC Dirk Zimoch
Re: PREC Eric Norum
Prev: JCA maintainers John Maclean
Next: RE: PREC Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: PREC Eric Norum
Next: Re: PREC Brian McAllister
